Activity › Forums › Avid Media Composer › HDV to PAL ?
HDV to PAL ?
Posted by Andreas Glatz on June 24, 2007 at 11:43 pmHi,
i have some Material captured in HDV and then transcoded to Avid
Andreas Glatz replied 19 years, 2 months ago 2 Members · 2 Replies -
Erik Pontius
June 25, 2007 at 3:13 amWhat do you mean by “stabilized in AE”? Do you have clips with jumpy camera work you are trying to smooth out with AE tracker tools “motion stabilization”? If so, I wouldn’t recommend converting to PAL just yet because of the frame rate differences between NTSC (29.97) and PAL (25).
Probably better to do all your work in HD before downconverting to NTSC . If your end result is going to be PAL it might be better to do this with an application like Canopus Procoder or similiar transcoding software that can properly handle the framerate differences (Avid will probably do a less than desirable job at this) or see if there is a video duplication house that can do the conversion with a dedicated hardware standards converter.
Erik
Andreas Glatz
June 25, 2007 at 8:27 amHi Erik,
first, thanks again for your great help! I handled the material for the first run like you recommended, avid out DNxHD QT reference into AE, then back to Avid QT with DNxHD. That worked just fine, but the HD footage slows down AE massively compared to PAL.
The material i have is HDV 1080i50, so there
