Activity › Forums › Apple Final Cut Pro Legacy › HDV to FCP to widescreen iDVD
Posted by John West on April 29, 2007 at 11:55 amHello, all.
My editor buddy is (understandably) in SD/HD/4:3/16:9 Hell. Since this may one day be me, I am posting the following query:
Can one capture NTSC HDV from a Sony camcorder in 16:9, edit a project in FCP5 in widescreen standard def, and then master that standard def widescreen Quicktime movie in iDVD for playback on a regular 4:3 TV, yet maintain an option for playing the same DVD on a widescreen TV by switching the DVD player (or TV) to widescreen mode?
Can anyone advise as to the simplest exact workflow and capture/export settings?
(It’s a simple question, after all! *wink*)
Many Thanks!
– JW
P.S. And what if he wants to up-res the whole shebangy to HD in the future?
Brian Paterson replied 16 years, 11 months ago 5 Members · 8 Replies -
Tom Wolsky
April 29, 2007 at 2:27 pmYes. The material will be letterboxed on a standard aspect television and widescreen on a widescreen television.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Walter Biscardi
April 29, 2007 at 2:31 pm[John West] “P.S. And what if he wants to up-res the whole shebangy to HD in the future?”
Just edit in HD to begin with. HDV is a very small codec and you can create an SD DVD right from the HDV timeline. I do this all the time with DVCPro HD projects. Simply select 16:9 as the aspect ratio in Compressor when you create the MPEG-2 for the DVD. Then when the DVD is played, it will come up letterboxed on a 4:3 monitor and 16:9 on a widescreen monitor with the correct DVD connections and settings.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Miodrag Ristic
April 30, 2007 at 3:39 am[Walter] –
Walter,
Sorry for interjecting, are you trying to say that you can capture HDV into HDV
timeline and then just send it to compressor for a regular DVD-5 (SD – DVD).
(you mentioned HD, HDV and DVCPro HD, so I’m a bit confuesd there)Thanks
Mick
FCStudio 5.1.2, OS X 10.4.6, G5 2.3 Dual, 2 Gig
Walter Biscardi
April 30, 2007 at 3:41 am[Miodrag Ristic] “Sorry for interjecting, are you trying to say that you can capture HDV into HDV
timeline and then just send it to compressor for a regular DVD-5 (SD – DVD).”Yep, at least it works fine with a DVCPro HD timeline.
Miodrag Ristic
April 30, 2007 at 3:51 amThanks Walter,
Why the choice of DVCProHD?
I’m just trying to get the complete workflow in my head (still on DV)
before I jump and buy Canon XH A1, heard/read many people
complaining about HDV.
Do I need an MXO (cheapest way to go) to monitor HDV as well?
So far I’ve learnt that my current Firewire 800 drives will be OK for HDV.Am I missing something here?
Thank you
Mick
FCStudio 5.1.2, OS X 10.4.6, G5 2.3 Dual, 2 Gig -
Walter Biscardi
April 30, 2007 at 11:52 am[Miodrag Ristic] “Why the choice of DVCProHD?
complaining about HDV.”HDV is a great aquisition format, not a good editing format due to all the rendering / conforming that must be completed before editing to tape. There is a also more color information in DVCPro HD since it’s a true 4:2:2 format so it holds up better to color correction. DVCPro HD is just a much easier format for Post than HDV, though the new ProRes 422 codec could change that next month.
Brian Paterson
October 26, 2009 at 1:24 pmI have read that idvd does it’s own compression therefore no need to use fcp’s compressor before sending to idvd. In fact this could cause footage to be compressed twice thereby losing quality. Is this true or a myth.?
Yesterday I completed my first ever HDV wedding video with an XHA1 and made a short test. I made a self contained quicktime file straight from fcp and burned it at professional quality in idvd. Quality looks fine on my widescreen telly but image is squished on my old standard one. ( there is probably an anamorphic tick box somewhere I missed ) Apart from that there dosen’t seem to be a problem. Thought I would write the whole two hour video today but contemplating the file size thought I would do it as a reference movie instead of self contained before sending to idvd but just read somewhere that I can’t make a reference file from fcp if it’s in hdv. Is this true? or another myth.
It’s going to take a long time so would like to start off on the right foot.
Many Thanksbrian paterson
