Activity Forums VEGAS Pro HDV to DVD problem
  • HDV to DVD problem
    Posted by Robert Matre on October 6, 2010 at 9:38 pm
    Hi Folks!
    I need som help here..
    I got some problem when rendering my hdv 25f footage in Vegas 9 for dvd architect. The result doesnt give me the result i want, its not sharp enough and it looks like it got som interlace problems during paning.
    I’ve selected best quality and Lower Field First.
    Do anyone know how i can get the best result for making DVD out of my hdv fottage?
    Thanks alot!
    Danny Hays replied 15 years, 11 months ago 3 Members · 2 Replies
  • Scott Francis
    October 6, 2010 at 10:34 pm
    I add a TOUCH of sharpening (using Sony’s FX) and have kept some of the “sparkle” if you will. Be careful though if you are having interlacing issues. Try a short section and see if that helps!!! I always do this at the very end of my renders. Meaning, I render to 720p first then to MPEG 2 for DVD, at that stage I add my shapening…good luck!
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Danny Hays
    October 7, 2010 at 4:03 am
    Try setting your project prefs to HDV 1440 x 1080 24.97, Progressive and set deinterlace type to blend. You should see a difference right away in the preview, at least you should not see any interlace lines. Also render to Progressive, blend as well. Hope this helps, Danny Hays
