Activity Forums Adobe After Effects HDV to DVCPROHD
  • HDV to DVCPROHD
    Posted by Sergio Deustua on March 6, 2007 at 9:41 am
    Hello everyone.
    I have some footage recorded as HDV 1080i 50. Looks OK, but my project is DVCPROHD 720p 60.
    What do you think is the best method to convert the HDV material into DVCPROHD?
    Thanks.
    Sergio Deustua replied 19 years, 6 months ago 2 Members · 4 Replies
  • George Loch
    March 6, 2007 at 3:36 pm
    If you have a Blackmagic card, it can capture directly to whatever codec you like in real-time via the HD-SDI input. If you are looking for a software-based option then you are looking at some kind of compression suite or even AE will do it but, it’s not ideal.
    -gl
  • Sergio Deustua
    March 6, 2007 at 5:48 pm
    Thanks.
    I have a blackmagic card, but I don
  • George Loch
    March 6, 2007 at 5:54 pm
    You will probably need to just recompress it using whatever tools you have available then. Just make sure you get the translation correct in terms of fields, rates ,etc. AE will do it but it will be slow and I think one of the compression tools will do a better job.
    -gl
  • Sergio Deustua
    March 7, 2007 at 6:54 pm
    Thanks.
    I
