Activity Forums Apple Final Cut Pro Legacy HDV to DVCProHD speed effect issue….
  • HDV to DVCProHD speed effect issue….
    Posted by Adrian Zehn on February 19, 2007 at 6:41 pm
    I am onlining a project that was shot in HDV.
    When I look at the offline clips the codec says DV / DVCPro – NTSC. The frame rate is 29.97.
    The project was then uprezzed, by re-digitizing the footage using the DVCProHD codec with a Kona card.
    In the online version, clips that have been slowed down using the ‘Speed’ effect have a bad ‘staggered’ look – it’s not smooth like in the online. If we use the ‘shift fields’ filter at ‘+1’ on these clips, the effect looks a bit smoother, but still not as good as the online version.
    Does anyone know anything about this problem and any solutions?
    Thanks in advance,
    AZ
    Adrian Zehn replied 19 years, 7 months ago 1 Member · 1 Reply
  • Adrian Zehn
    February 19, 2007 at 7:04 pm
    I just realised I used the term ‘online’ when I should have said ‘OFFLINE’ a few times in my post, making it confusing. Below is the fixed version…..sorry!:
    In the online version, clips that have been slowed down using the ‘Speed’ effect have a bad ‘staggered’ look – it’s not smooth like in the OFFline. If we use the ‘shift fields’ filter at ‘+1’ on these clips, the effect looks a bit smoother, but still not as good as the OFFline version.
    Thanks in advance,
    AZ
