Activity Forums Apple Final Cut Pro Legacy HDV to DVCPROHD or PRO RES 422?
  • HDV to DVCPROHD or PRO RES 422?
    Posted by Toby Roberts on June 6, 2009 at 6:32 pm
    I will be on-line editing a 60 min documentary originally shot on HDV 1080i, using a Kona LHe card. I’ll deliver a DVCPRO HD tape for color correction, and final masters will most likely be on DVCPRO HD tape. The program has very little graphics or animation.
    Should I ingest the original HDV source material using the DVCPRO HD codec, or is there any benefit to using the PRO RES 422 codec?
    I can either capture using Firewire HDV to PRO RES 422, or use HDSDI to either codec. Any significant difference in image quality?
    Toby
    Toby Roberts replied 17 years, 3 months ago 3 Members · 3 Replies
  • Shane Ross
    June 7, 2009 at 6:21 am
    If you are going to be outputting to DVCPRO HD tape, then you should capture the HDV as DVCPRO HD. ANy benefit you get from ProRes will be thrown out the window as soon as you output to DVCPRO HD tape.
    Shane
  • Walter Biscardi
    June 7, 2009 at 11:58 am
    [Toby Roberts] “Should I ingest the original HDV source material using the DVCPRO HD codec, or is there any benefit to using the PRO RES 422 codec? “
    Capturing to ProRes definitely keeps the graphics cleaner. We output to two Panasonic 1400 DVCPro HD decks and we switched over the ProRes workflow for the cleaner graphics and to work in the full raster frame size.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Toby Roberts
    June 7, 2009 at 2:39 pm
    Thanks for the advice. I’ve had trouble recapturing HDV in the past, so now knowing that both codecs will yield very similar results, I’ll choose the ingest process that’s the easiest.
    Toby
