Activity › Forums › AJA Video Systems › HDV to DVCPro HD
  • HDV to DVCPro HD
    Posted by Paul Belanger on December 17, 2005 at 12:28 am
    I have a project where half of my tapes (DVCPro HD) have already been captured.
    I have 18 other HDV tapes that need to be captured.
    Can I capture the HDV tapes in Final Cut Pro 5 using the DVCPro HD settings.
    I have a Kona 2 card.
    Or do I have to convert my HDV clips once I capture them.
    Paul
    Uli Kunkel replied 20 years, 9 months ago 5 Members · 5 Replies
  • David Battistella
    December 18, 2005 at 7:19 pm
    Since the Koan does not have analog inputs I would have to sasy that the best thing you could do is capturethe native HDV stream and then convert all of the clips to DVCPRO codec.
    David
    see this:
    https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=83&page=https://www.creativecow.net/articles/battistella_david/recapturing_HDV/index.html
  • Michael Garber
    December 18, 2005 at 11:32 pm
    …or rent/buy an AJA HD10A and convert the component analog to HD-SDI. Will take far less time than conversion.
  • Paul Belanger
    December 19, 2005 at 3:11 am
    How is the audio working in this set up.
    Audio from HDV deck into the Kona 2 K box.
    I switch the Kona panel to analog in.
    Monitor out of the audio out of Kona 2 K Box.
    Am I correct on all this?
  • John Ladle
    December 19, 2005 at 3:49 am
    the kona 2 can do HDV, from the Canon camera because it is SDI. 8 bit uncompressed 1080 hd off that lense is nice too…
    for analog sources like the sony, the kona LH/lhe can take 1080 hdv to 1080 uncompressed or DVCPRO HD. 720 to 720 as well.
    also, the hd10a is very popular with kona 2 owners. analog video to the hd10a, analog audio to either a flying cow (if you can find on these days) or the shortly (any day now????) shipping ADA-4.
    whatever you do, try not to go HDV to DVCPRO hd in the timeline. it takes a while and the quality is not there.
  • Uli Kunkel
    December 19, 2005 at 4:38 pm
    You could also check out http://www.miranda.com and try their HD-Bridge. It will take your HDV and convert directly to HD-SDI while keeping timecode. It works with the JVC and Sony HDV formats.
    I’m avoiding this solution right now, however. The HD-Bridge is a fabulous product, but I’m taking my HDV footage to film, and I want to avoid the generational loss.
