Activity › Forums › Compression Techniques › HDV to DV. Leave as Upper Field???
  • HDV to DV. Leave as Upper Field???
    Posted by Fletch on February 10, 2006 at 12:49 pm
    HI
    I’m trying to Compress an HDV movie to DV-PAL. As I understand it- HDV is Upper Field dominant, whereas DV is Lower Field dominant, so:
    Do I tell Compressor to leave the fields ‘Same as source’, or do I tell it to go to ‘Lower’? Or even ‘Upper’ (which surely is the same as leaving it ‘same as source’?
    Fletch
    Charles Simonson replied 20 years, 7 months ago 2 Members · 1 Reply
  • Charles Simonson
    February 11, 2006 at 3:47 am
    If you are going to mix the HDV to DV material with other DV native material (or print to a DV tape), then you should adjust the field to lower. If your entire project is going to use HDV material downconverted to DV and your final output is going to be for DVD or the web, then it would likely be best to leave the fields same as source.
