Activity › Forums › Apple Final Cut Pro Legacy › HDV to Blue-ray
  • Peter Dewit
    May 23, 2007 at 9:00 pm
    it’s kind of sad that DVDSP doesn’t support bluray yet. HDV is actually a good candidaite for it since MPEG 2 is supported on blu-ray format without further compression. Finally we’d have a way to output HDV natively without taking a quality hit.
  • Miklos Philips
    June 11, 2008 at 6:55 pm
    I don’t know where the additional $3,000 investment figure comes from, bc you can do it for almost half (this is assuming you already have FCS2).
    Current Mac workflow for creating Blue-Ray discs:
    1.) FCP -> Export your HD master
    2.) Encode with Compressor: MPEG2 select for Blue-Ray (use an HD encoding existing setting that comes with Compressor and just select “Blue-Ray” and tweak – but you don’t have to touch it…
    3.) Build Blue-Ray with Encore (throw away Premiere 🙂 (cost $800)
    4.) Burn with Pioneer BDR-202B (Cost $400)
    5.) Play back with PlayStation 3 (Cost $400)
    Point Zero Pictures
    <https://www.pointzeropictures.com>
Page 2 of 2
