Activity Forums Apple Final Cut Pro Legacy HDV to 1080 settings using KONA LH
  • HDV to 1080 settings using KONA LH
    Posted by Jhaughey on August 9, 2006 at 9:20 am
    hello,
    has anybody successfully done this?
    I’m using all the most up to date equipment…
    I’ve set up everything as I think it should,
    however when it captures, the frame size is half what it should be, i.e 960×540….
    Also on the kona control panel, everything looks fine (its getting a 1080 compnent signal and analog audio,
    however, there is a thin red line around the analog in icon… anyone have the same issues?
    I’m using the Sony M10 deck. its all in PAL.
    would any of you kind contributors care to set me straight on what the settings should be?
    thanks,
    Joe
    Jhaughey replied 20 years, 1 month ago 2 Members · 2 Replies
  • Mark Maness
    August 9, 2006 at 4:29 pm
    Have you tried capturing in DVCPRO HD? That’s how I use mine all of the time. DVCPRO HD handles everything beautifully including graphics. As a matter of fact, that how most of us use our HDV equipment. HDV captures in FCP are very troublesome at best.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Jhaughey
    August 9, 2006 at 9:42 pm
    thanks Wayne,
    I’ll give it a go…
