Activity › Forums › Apple Final Cut Pro Legacy › HDV timeline footage to HD monitor?
  • HDV timeline footage to HD monitor?
    Posted by Phil Giriodi on October 9, 2011 at 4:13 am
    Mac Intel OS 10.6.8
    FCP 7.0.3
    I am still unable to view HDV footage from my timeline on my HD monitor using a Blackmagic Intensity internal card as output.HDMI TO HDMI cable.
    The 1440:1080 is grayed out. All captured footage is displayed as 1920:1080.
    I was struggling with this problem a couple of weeks ago but had to go out of town before a solution. The two suggestions from forum members did not solve the problem.
    Your help would be most appreciated.
    Phil Giriodi replied 14 years, 11 months ago 2 Members · 5 Replies
  • Jerry Hofmann
    October 9, 2011 at 10:51 pm
    Make sure you’re drivers for the card are the latest?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Phil Giriodi
    October 10, 2011 at 1:42 am
    Thanks Jerry. You did it again! That is exactly what the problem was. I was under the impression that I had the latest drivers but I did not.
    Thanks again.
    All the best,
    Grant
  • Jerry Hofmann
    October 10, 2011 at 12:57 pm
    Hey, it’s a standard response to the problem… Glad it worked this time!
    Jerry
    Current DVD:
  • Phil Giriodi
    October 10, 2011 at 2:56 pm
    Jerry,
    A big problem: After turning the system off for the night FCP will no longer boot this morning. It goes through the motions, however, it gets to a certain point and then disappears.
    Tried everything that I can think of.
    What do you suggest?
    Thanks.
    Grant
  • Phil Giriodi
    October 10, 2011 at 3:38 pm
    Success! Reinstalled Blackmagic software from internet. Now working as expected. May have to reinstall each time system is booted which doesn’t seem right.
    Anyway, thanks again Jerry.
