Activity › Forums › Apple Final Cut Pro Legacy › HDV slow rendering
  • HDV slow rendering
    Posted by Dave Yakir on July 11, 2005 at 4:33 am
    We’re working with a G5 dual 1.8 with 4.5 gig of RAM and the rendering time is pretty slow for HDV footage. Is there any settings or any special things I’d need to do with FCP 5 to speed up the rendering time? Any help and info would be much appreciated!
    Dave
    Dave Yakir replied 21 years, 2 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    July 11, 2005 at 2:03 pm
    I’m not working much with HDV, but it doesn’t much surprise me that it’s slowish… I suspect that if you used the intermediate codec instead of HDV “native” codec, things would improve…
    Reason “native” HDV is slow is because it’s not an I frame codec, meaning it’s calculating some of the frames: the ones that are only recording the difference between true I frames. Where the intermediate codec is ALL I frames, much like DV or uncompressed video is… less to calculate… Theory states that there would be a signal loss doing this (compressing to the intermediate codec) but I have a feeling that if you try it, you might not actually see a lot of difference. Dunno, again not really using HDV much.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Steve Connor
    July 11, 2005 at 9:43 pm
    Plus the fact it’s HD of course, more pixels more calculations needed – slower renders.
    When you say slow – exactly how slow do you mean, say compared with DV?
    Steve Connor
    Cardinal HD
  • Dave Yakir
    July 11, 2005 at 9:54 pm
    well for about 1 and a half minutes, it takes about 8 min of rendering time…
    I have not worked with the system yet, but will be working on it in a week and they called me with this issue… also, before doubling the memory (was 2 gigs) FCP 5 would crash frequently. The people I’m working with captured the footage through iMovie and used the QT’s created to work with FCP. Is there any sort of issues with doing this, or is it a safe way to capture? Personally I use FCP to capture everything but they did it this way and it ran into the crashing problem (but when the mem was doubled to 4 gigs, the crashing problem went away).
    Any suggestions/techniques you suggest to make the editing process as smooth as possible? There is a lot of dailies to be captured and I dont really have the time to run into major problems.
    Any help would be great!
    Dave
