  • Posted by Patrick Tyler on September 22, 2005 at 6:13 pm
    When I put a HDV file into a SD timeline and then slow it down to 50%, no matter what filter I put on it (de-interlace, blend fields, shift fields, etc.) I get a strobing effect. If you step through the timeline the image will go forward for a frame or two and then it will actually go backwards on the next frame, then forward again. Can anyone tell me how to solve this problem?
    Tom Wolsky replied 21 years ago 3 Members · 6 Replies
  • Tom Wolsky
    September 22, 2005 at 7:01 pm
    What HDV specs did you capture with? What are the specs for the sequence?
  • Patrick Tyler
    September 22, 2005 at 7:04 pm
    I digitized HDV1080i60 and the timeline is 8-bit uncompressed.
  • Patrick Tyler
    September 22, 2005 at 7:09 pm
    Here is something else weird. If I put the clips into a HDV1080i60 timeline and slow them down to 50% and add a deinterlace filter with the upper field, the clip looks fine, then if I export that sequence out as a HDV1080i60 self contained movie and reimport it and then put it into the 8-bit uncompressed SD timeline, it looks OK. I don’t want to have to do this for every clip because I’m using lots of slo-mo, but it is strange that it worked.
  • Graeme Nattress
    September 22, 2005 at 7:35 pm
    HDV is upper, is your 8bit upper or lower field?
    Check out the demo of Standards Converter 2.5.2 at http://www.nattress.com and try out “G Map frames” which does awesome 50% slowdown. I’ve not tried it downconverting at the same time, but if you find you need that as a feature, please email me and I’ll figure it out for you.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Patrick Tyler
    September 22, 2005 at 8:04 pm
    Tom, can you please give me your insight?
  • Tom Wolsky
    September 22, 2005 at 8:05 pm
    As Graeme said, the sequences don’t seem match the material, and it sounds as if the fields are reversing.
