Activity › Forums › Apple Final Cut Pro Legacy › HDV setups with FCP
HDV setups with FCP
Posted by Doug Moldawsky on March 16, 2007 at 9:58 pmI have some footage shot with a Z1 Sony in HDV. I haven’t been able to get final cut to accept any HDV settings to log and capture???? I can capture as standard def dv which arrives letterboxed from the camera. I’d prefer to stay in HDV mode throughout. ANy suggestions would be appreciated? Thanks, Doug
Walter Biscardi replied 19 years, 5 months ago 5 Members · 7 Replies -
Tim Danyo
March 16, 2007 at 10:24 pmAre you editing in FCP4.5? You need to be in 5 do edit in HDV.
Tim
Steve Connor
March 16, 2007 at 11:15 pmJust to be clear, have you tried capturing in HDV with the downconvert mode on the camera switched OFF?
Doug Moldawsky
March 16, 2007 at 11:31 pmThe downconvert options are for letterbox, squeeze, and edge crop, but not off….?
Ben Holmes
March 16, 2007 at 11:54 pmThe camera either outputs DV or HDV – you need to set the output to NOT downconvert – simple as that.
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live OB operations.
New HD edit/slomo truck on the road this month. Dual FCP systems/6 slomo positions.
Doug Moldawsky
March 19, 2007 at 5:11 pmOtay…got it. thanks. A little rtfm and I then discovered Sony’s ilink is essentially firewire. Turned off downconvert and it arrivews correctly. Allthough fro some reason, I can’t seem to preview audio in this mode…….? Anyways, Thanks for the tip.
Walter Biscardi
March 19, 2007 at 5:20 pm[Doug Moldawsky] “Sony’s ilink is essentially firewire.”
Sony has to have their own name for everything. 🙂
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
