Activity › Forums › Apple Final Cut Pro Legacy › HDV QT exports have poor playback
Posted by Joe Murray on December 31, 2006 at 10:45 amHi, I’m editing a 1080 50i project. Playback is good in full screen mode from within FCP, but when I export a movie with the same settings to QuickTime Pro playback is then jerky with visible stutters at the edits. Any ideas?
Rafael Amador replied 19 years, 9 months ago 5 Members · 8 Replies -
Walter Biscardi
December 31, 2006 at 12:18 pmWhat are you exporting to? Are you playing the media off a fast hard drive or the system drive? We’re cutting an entire series in 1080i/50 DVCPro HD and don’t have any issues with QT exports playing off our media drives.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Joe Murray
December 31, 2006 at 1:32 pmHi Walter, I’m exporting to the same firewire 800 drive that the sequence is using with no problems. Setting are “export QT movie using current settings”
Output file is: Apple HDV 1080i50, 1440 x 1080 (1888 x 1062), Millions
16-bit Integer (Big Endian), Stereo, 48.000 kHz, Data rate 26.57 mbits/sec – same as the capture clips. (I still have the old Cinewave card in there ?!?- oh happy days)System Dual 2.5 G5. Apple 23′ monitor
Walter Biscardi
December 31, 2006 at 2:14 pmNot really sure then. HDV is a very weird codec and folks seem to have a lot problems with it that don’t affect other codecs. We convert all our HDV to DVCPro HD via the Kona card when we use that format.
Chris Poisson
December 31, 2006 at 3:16 pmJoe,
If you don’t have a Kona card or a converter box, why not try exporting through Compressor to DVC Pro HD? It could take a while but it may work.
Joe Murray
December 31, 2006 at 4:04 pmThanks Chris, I’ll give it a go, but wont the files be huge?
Chris Poisson
December 31, 2006 at 11:43 pmFiles won’t be that huge, DVC Pro HD is compressed, but it looks great.
Rafael Amador
January 2, 2007 at 11:32 amDid you try to set the QT player to”high quality”? Command-J. Click Video Track, and check the High Quality option.
Usually the QT plays at a medium quality.
Salud,
Rafael
