Activity Forums Apple Final Cut Pro Legacy HDV project settings for flash output
  • HDV project settings for flash output
    Posted by Lawrence Robbin on November 7, 2008 at 5:34 pm
    This is a question about having the best settings for an HDV project that will end up as flash files…
    I am about to edit a project using HDV. I will be capturing video files from the Sony PMW. After the project is edited to completion, I want to be able to easily convert it to flash files.
    Are there are render settings and/or other system settings I should be aware of and use to get the best possible results – i.e., video files that will be easily amenable to conversion to flash files.
    Lawrence Robbin replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
