Activity Forums Apple Final Cut Pro Legacy HDV project – SD output
  • HDV project – SD output
    Posted by Amy Mogavera on July 7, 2009 at 3:18 am
    So the project was shot HDV 1440×1080 23.98fps (1080p24). It was edited in FCP on a sequence with the same settings.
    So now we need to export to tape – SD 29.97.
    What is the best way to do this?
    Thanks in advance,
    Amy
    David Soriano replied 17 years, 2 months ago 5 Members · 5 Replies
  • Arnie Schlissel
    July 7, 2009 at 4:56 am
    [Amy Mogavera] “So now we need to export to tape – SD 29.97.
    What is the best way to do this?”
    Simply connect the appropriate deck to your capture card & set your card to downconvert.
    Assuming you have an HD capture card and access to the appropriate deck…
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Stace Carter
    July 7, 2009 at 9:03 am
    or…
    Nest your HDV sequence in an SD sequence. Pan and Scan to taste, then Render like mad.
    Cheers,
    Stace
    Apple Certified Trainer, Final Cut Pro Level I
    Final Cut Studio Master Pro
  • Amy Mogavera
    July 7, 2009 at 8:18 pm
    My next question-
    Which settings should I use for my SD sequence going to miniDV?
    720×480 NTSC DV (3:2)?
    640×480 NTSC (4:3)?
  • Keith Heard
    July 7, 2009 at 9:42 pm
    720×480 NTSC DV.
    Keith Heard
  • David Soriano
    July 8, 2009 at 3:02 pm
    this works like a charm, too.
