Activity › Forums › Adobe Premiere Pro › HDV-Project / Compressor: I-Frame only…?
Posted by Uwe Lansing on September 4, 2006 at 9:11 amHi,
if you start a new HDV-project you
Uwe Lansing replied 20 years ago 2 Members · 4 Replies -
Tim Kolb
September 4, 2006 at 3:22 pmIt’s greyed out correct?
It’s part of the settings. I-Frame only MPEG just takes some stress off the processor as it can be encoded sequentially.
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Tim Kolb
September 4, 2006 at 7:34 pmThere were a couple of directions of development going on with this feature and what I do recall can’t necessarily be discussed…but MPEG in the form used in HDV is made up of I frames (complete) P frames (predictive…based on prediction from I frames) and B frames (bidirectional frames computed from I and P frames).
The sequence would flow by like this: IBBPBBPBBPBBPBBI (“I” signifies new GOP for 15 frame HDV2)
First the I frame is computed, then the next P frame, then the B frames in between them, then the next P frame, then the B frames in between…all the way to the point where the next “I” frame to start the next GOP is computed before the last two B frames of the first GOP can be created…
This is why video with the same data rate as DV handles like it’s about 5 times as much data with the same PC.
By using all I frames for your preview renders, they get done faster. PPro does not use preview renders for exports, so when you export to HDV, that is a separate procedure.
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
