Activity Forums Adobe After Effects HDV problem
  • HDV problem
    Posted by Kevin Herrin on May 10, 2006 at 5:19 pm
    I have some hdv video (720p) that I have dropped into a D1 comp for keying. Everything looks fine until I look at the rendered video. The .mov looks terrribly aliased, but it is only the keyed part that looks bad.
    Do I need to do something to the hdv video before I drop it into a sd comp?
    Kevin
    Kevin Herrin replied 20 years, 3 months ago 2 Members · 5 Replies
  • Simon Carlson-thies
    May 10, 2006 at 5:51 pm
    You have hit one of the biggest problems with HDV its so compressed that it doesn’t key well. Also its hard to mix with other footage like SD, because of how limited the color information is.
    Can you post a sample of what it looks like…
    What render settings are you using?
    Are you viewing the footage on a monitor or an NTSC monitor?
    Simon Carlson-Thies
  • Kevin Herrin
    May 10, 2006 at 6:13 pm
    Thanks Simon,
    The quality of the key is fine, actually better than I expected. It is only when I render the video out that I get bad video. I have tried uncompressed, video and h2.64 codecs all with bad results.
    What I am seeing is moire pattern stuff on shirts and hair. Really bad.
    Kevin
    May 10, 2006 at 7:44 pm
    have you tried a lossless codec to see if that makes a difference?
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Kevin Herrin
    May 10, 2006 at 7:46 pm
    I am trying that right now, will let you know.
    Kevin
  • Kevin Herrin
    May 12, 2006 at 3:06 pm
    Just an update, Lossless is certainly the way to go. Looks much better, I also added the reduce interlace effect and that helped smooth the moire patterns nicely.
    Kevin
