Activity Forums Apple Final Cut Pro Legacy HDV print to video-no image
  • HDV print to video-no image
    Posted by Alan Stephens on August 15, 2010 at 12:11 am
    I’m trying to print to video in FC7 pro, to my Sony HDV deck. I’ve done this with FC6 but it was hit and miss. I first tried to record my prores (HDV) project and everything runs except the screen on the deck is black during transfer, so nothing is being recorded.
    I tried also by exporting the timeline to compressor and down converted back to HDV and put that on a new timeline. I’ve tried the deck with various input settings, such as HDV, Auto, and it still comes out black. Everything in FC7 seems in order during this process, bars, countdown, then the video plays on the monitor, just not the deck. FC even starts the deck. I’ve also verified the sequence settings are HDV.
    Why is this so elusive?
    Alan Stephens
    Alan Stephens replied 16 years, 1 month ago 4 Members · 6 Replies
  • Francis Hughes
    August 15, 2010 at 12:13 pm
    I have this problem in FCP 6 the only way to get it working is to restart FCP, and try it again, try it again and try it again, then for no reason it would work! Also nesting my sequence has been known to help.
  • Alan Stephens
    August 15, 2010 at 3:06 pm
    I’ve tried this multiple times with a nested sequence restarting FC and rebooting with no success. I’ve also tried it with my Sony HDV zu1 camera. I think the problem is in the routing. When I print to video I get a message about it not being routed right. It seems to me the video should be routed to an HDV output instead of the Desktop preview. When I go there to reset the HDV outputs are all greyed out.
    How do I get this to be selectable?
    Alan Stephens
  • Richard Harrington
    August 15, 2010 at 3:15 pm
    Run easy setup that matches you sevices
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Zane Barker
    August 15, 2010 at 3:30 pm
    [Alan Stephens] “I first tried to record my prores (HDV) project”
    You cannot print a pro res timeline to a HDV deck, the deck will only accept a HDV signal.
    [Alan Stephens] “I tried also by exporting the timeline to compressor and down converted back to HDV and put that on a new timeline”
    Not the best way of going about it. First make sure the new time line has the proper HDV settings, then just simply copy and past the your old time line to the new one and render.
    Bust most important keep in mind that when you convert back to HDV from pro res you will loose some quality in your video. Most editors would agree that HDV may be a ok acquisition format but definitely not a good editing format and a even worse mastering and archival format.
    I myself shoot HDV but wont edit in it, I capture directly to pro res and then, master and archive onto hard drives that or course are backed up.
    **Hindsight is always 1080p**
  • Alan Stephens
    August 15, 2010 at 7:25 pm
    I now capture all my hdv directly to pro res. I will try nesting the pro res timeline into an hdv timeline.
    I’m not really mastering the project but the plan is to run a projector from the HDV component for a live show next week. This will look a lot better I think than a DVD.
    The real problem here is the video doesn’t make it to the deck from FC. It is conforming it now.
    I’ll post with the results.
    Alan Stephens
  • Alan Stephens
    August 15, 2010 at 8:23 pm
    I tried the nested sequence and still no image on the deck.
    The external video output for HDV is still greyed out.
    How do I make it selectable?
    Alan Stephens
