Activity › Forums › Apple Final Cut Pro Legacy › HDV Playback
  • Posted by Dan Archer on May 8, 2007 at 7:16 pm
    This is my first time to capture and use HDV. It captures fine, but on playback it is skipping frames, and it seems to be consistant. Is this just the way fcp plays back HDV or should i be seeing this play back smooth as silk. Do I need to drop resolution or something to get smooth playback. I can easily use whjat I am seeing, but im curious.
    any help would be appriciated
    System = quad g5, aja Lhe, 2 tb storage, 3 gig of ram latest FCP
    Ingested Firewire, HDV 1080i
    Dan Archer replied 19 years, 4 months ago 2 Members · 3 Replies
  • Walter Biscardi
    May 8, 2007 at 7:35 pm
    As long as your Easy Setup is set to the correct HDV preset, your media drives are fast enough and you have no filters applied to the clips, playback should be normal.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Dan Archer
    May 8, 2007 at 7:37 pm
    Thanks. Ill be back at the grind soon. Ill see what happens.
  • Dan Archer
    May 9, 2007 at 4:14 pm
    A stupid as i look This problem was just a wrong setting. Playback frame rate set to half…
    I may look goofy but the more i get into this box. I love what it is capable of. Thanks again for your help.
