Activity › Forums › Apple Final Cut Pro Legacy › HDV playback problems in FCP
  • HDV playback problems in FCP
    Posted by Bcfilm on January 5, 2006 at 6:50 pm
    Hello.
    Working in Final Cut Pro HD. I have my new G5 connected to my Sony M10U deck via Firewire. I have the deck connected to a broadcast quality Sony PVM1954Q monitor.
    The problem – when working in Native HDV on the timeline, full motion does not appear on the NTSC monitor just single frames of the HDV image at the start and stop points. I have tried many of the sequence set ups in the menus, I have also tried changing input and output functions on the deck via the internal menus of the deck, but can’t seem to get it.
    I know that the signal path is connected correctly because
    Full motion DOES appear on the NTSC montior when using
    basic DV sequences.
    Any help would be appreciated it.
    Thank you.
    Brian C.
    Kevin Monahan replied 20 years, 8 months ago 5 Members · 4 Replies
