Activity Forums Apple Final Cut Pro Legacy HDV PAL to NTSC conversion, best method?
  • HDV PAL to NTSC conversion, best method?
    Posted by Ben Ged low on December 7, 2006 at 12:31 pm
    104 minute HDV PAL film just completed. Have PAL Quicktime master. Need to convert to NTSC master … (the both to go to DVD)
    Best method to accomodate this cruel deadline?
    I’ve tested: export HDV PAL out as DVCPRO 50 HD, de-interlaced, and then ‘conformed’ it to 23.98fps with Cinema Tools. The audio sounds a quarter tone ‘low’. Is there a fix for this? I haven’t output the whole 104 minutes … don’t know if there will be sync problems.
    Just now I tried to output the 104 minutes from HDV PAL to DVCPRO HD PAL (de-interlaced) and FCP is telling me it will take 14 hours. That seems a bit extreme. I did a test last month, and I don’t remember it taking much longer than exporting straight HDV. FCP has been acting up on this system (in the wilds of New Zealand) for the last two weeks. Wondering if it isn’t yet another symptom of something ‘off’ with this FCP (re-installed twice, Os re-installed once, still buggy).
    Any help would be most appreciated. Producers anxious. Deadline tomorrow.
    Thanks, Ben
    Jeremy Newmark replied 19 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    December 7, 2006 at 12:37 pm
    [Ben Ged Low] “Any help would be most appreciated. Producers anxious. Deadline tomorrow.”
    This is something that should never be thought about at the end of the process.
    Are you converting HD PAL to HD NTSC? If so, a Terranex conversion is the only way I’ve found for this. There is no software conversion tool out there for this reliably. Graeme Nattress’ filter is only for SD.
    We have to do a 1080i/60 (NTSC) to 1080i/50 (PAL) conversion on our show starting with the third episode and I’ve only found two places so far that can handle this conversion. Thankfully one of them is here in Atlanta.
    Standards conversion must be thought about and tested BEFORE you start the edit. We spent a week testing SD NTSC to PAL conversions before we started episode 1 of Assignment Earth.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Meredith Holch
    December 7, 2006 at 2:58 pm
    Hi Walter, you answered some questions for me about pal to ntsc conversion (SD)a couple of weeks ago and suggested the Nattress software solution. Now I’m thinking I want to sort of start over and do a hardware conversion. I have an option of renting a Sony DSC 1024 digital scan converter for next to nothing which should do the trick, but do you have any idea if the quality is broadcast quality? Also, there are now quite a few inexpensive (under $400 new) standards converters on the market such as the ATLONA SB3690, or the CDM-830T (not sure who makes that one), and a couple others. I don’t trust the quality of any thing so inexpensive, but I don’t really have any idea! Since you said you thought about your own conversion issues for a week, did you learn anything about these options? Or do you have any other suggestions of something to rent or buy? Unfortunately, I have 40-50 tapes, so doing an Alchemy transfer at ($80- $100/tape) at a transfer house is out of the question. Then, I found a transfer house website that said they’d do it for $13/tape, but how do I know the quality is any good? I’d rather do it myself on a machine I can trust. Thanks!
  • Walter Biscardi
    December 7, 2006 at 3:02 pm
    [chokecherry] “have an option of renting a Sony DSC 1024 digital scan converter for next to nothing which should do the trick, but do you have any idea if the quality is broadcast quality? Also, there are now quite a few inexpensive (under $400 new) standards converters on the market such as the ATLONA SB3690, or the CDM-830T (not sure who makes that one), and a couple others”
    When I checked around the only equipment that was broadcast quality 1080i/60 to 1080i/50 or vice versa was over $100,000. I know of only one shop in Atlanta that has all the proper equipment to allow this transfer. I would not trust anything but this equipment for my broadcast projects.
  • Kevin Hamm
    December 7, 2006 at 6:47 pm
    Ok, so this is my experience, and while not extensive it did work. I cannot say that it was fun to sit through, but in the end, it worked better than I expected. The biggest problem that happens when converting between PAL and NTSC can be seen on shows like “Will & Grace” in the UK – the sound slips out. I was having the same issue, so I decided to two step the process.
    Export your video tracks to a PAL format from your timeline
    Export your audio to AIFF.
    Start new project in PAL format
    Import video
    Import Audio
    Export PAL movie.
    Now, this caused *none* of the problems that I was told to expect, and my project was a 30 minute corporate piece, with chromokeying, titling, and lots of full-view scene changes, but perhaps I was just lucky. YMMV
    Kevin Hamm
    Video, Web, Print and coloring books.
  • Meredith Holch
    December 7, 2006 at 9:32 pm
    Thanks Walter, well, but you are editing a TV show, right? and using the Nattress G-Converter? Of course my client isn’t sure
    their show WILL be on BBC, but they do want a professional high quality product, I guess they’re thinking in terms of Al Gore’s documentary genre.. So, do you know of a good enough hardware converter? Or do you think Nattress delivers that same quality? Clearly my eyes are not a good judge, because even FCP’s conversion looks OK to me, (there is none of the stuttering you mentioned), but I know from what I’ve been reading, that it is NOT Ok. Or, what are the specific specs I should be looking for that determine a good converter from a problematic one?
  • Michael Gissing
    December 8, 2006 at 12:21 am
    Software conversions that change length and sound pitch are not what you want. Correcting the 4.1% shift (around 3/4 of a semitone) requires serious audio processing like MPEX3 on a Pyramix system.
    I would go to a pro facility with a Terranex and do a real time dub so that length and pitch are maintained.
  • Jeremy Newmark
    December 8, 2006 at 5:36 pm
    [Walter Biscardi] – “Graeme Nattress’ filter is only for SD.”
    This is not true. You can use the Nattress filter for HD frame rate conversions, which is why there are HD resolutions under the “source pixel size” option of the plug-in. We have gotten very pleasing results converting 1080 HDCAM material from 25 to 29.97 using the the G-converter filter on two different features that we did. Granted, the best and fastest way to do this is with a Terranex, but Graeme’s plug-in works extremely well when going from PAL to NTSC frame rates. We have not had as good of success using it to go from 29.97 to 25, but this was coming from 23.98 material with a pull-down added. We have not tested it out with HD material actually shot at 29.97. Shake does a pretty good job converting HD material from 29.97 to 25, but it takes forever and is still not nearly as good as a Terranex conversion. It may be different for HDV material, but for the Nattress filter does work well with 25 to 29.97 HDCAM material.
    best regards,
    jeremy
