Activity Forums Apple Final Cut Pro Legacy HDV PAL and NTSC two camera system
  • HDV PAL and NTSC two camera system
    Posted by Leo Bartulica on July 14, 2009 at 11:19 am
    Hi
    I have one question regarding recording with two different camera system, one is PAL and other one is NTSC both Canon XH A1.
    Is it possible to edit bcs imho they will have the same video dimension but different frame rate, is that correct !
    Is it possible to have two different format (PAL and NTSC) on the same timeline, would it have sync problem…
    David Roth weiss replied 17 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    July 14, 2009 at 2:14 pm
    Yes, you can do this, however one camera’s format will not match the other, so one camera would have to be rendered in a sequence which matches only one of the cameras. It would be preferable to not do this of course.
    Which format do you need to deliver? The PAL material would look better in an NTSC sequence than the NTSC material would look in a PAL sequence too I’ll wager.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • David Roth weiss
    July 14, 2009 at 3:50 pm
    Leo,
    Anything is possible — with enough time and money you can change every pixel of your video, but you don’t save anything by shooting with two mismatched cameras.
    Production errors, such as the one you’re asking about here, will cost you big time in post, and it can jeopardize the quality of your entire production. Standards conversions are simply never as good the same video without the conversion, and cutting the two together shows the difference in almost every case. There is almost no worse mistake you can make than shooting with mismatched cameras, and using cameras with different standards would be the worst of the worst.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
