Activity Forums Blackmagic Design hdv output to SD on DigiBeta not working
  • hdv output to SD on DigiBeta not working
    Posted by Mathias Hekton on January 18, 2006 at 11:32 am
    I am trying to output an hdv sequence to a DigiBeta. The down conversion works fine and I can “crasch” it to tape with out problem. But how do I get it to work in “edit to tape”. It renders for a long time then it starts to output but all I get is black and no audio. Anybody have a clue?
    /Mathias Hekton
    Mathias Hekton
    Hekton Filmproduktion
    Dennis Irming replied 19 years, 3 months ago 3 Members · 3 Replies
  • Mactrix
    January 20, 2006 at 10:23 am
    I guess for this you have to make a software-downconversion inside FCP.
    Nest your HDV-sequence in a uncompressed 8-Bit sequence (be sure the
    8-Bit SD PAL sequence setting is set to upper fields).
  • Mathias Hekton
    January 20, 2006 at 10:51 am
    Thanks for the tip. That seems to work after a very long render. I was hoping there would be an easier way but this will have to work for now. Thanks
    /Mathias Hekton
    Mathias Hekton
  • Dennis Irming
    January 21, 2007 at 12:07 pm
    Tjena Mathias…..
    Detta
