Activity Forums AJA Video Systems HDV on an NTSC monitor through AJA IO LD
  • HDV on an NTSC monitor through AJA IO LD
    Posted by Marcosh on November 30, 2007 at 12:45 pm
    Hi everyone,
    Working with Final Cut Pro 6.0 on 10.4.11 here…I was wondering if I can monitor HDV (720p 24fps) footage on my NTSC monitor through my AJA IO LD…
    The material has already all been captured. I just would like to use my NTSC monitor for playback.
    Marcos H.
    Ed Dooley replied 18 years, 9 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    November 30, 2007 at 4:07 pm
    No, the ioLD is an SD only device and does not handle HDV material.
    Perhaps it’s time to upgrade to HD?
    Jeremy
  • Marcosh
    November 30, 2007 at 6:44 pm
    Thanks, Jeremy.
  • Ed Dooley
    December 3, 2007 at 3:39 am
    Hold on there bucko (it’s so difficult finding the right time to call someone that).
    Check this out:
    https://forums.creativecow.net/readpost/150/857018
    As a proud owner of a couple of Io products, I can confirm this. I still have 5.something on my PowerBook and it only updates to the current frame when you stop, but FCP 6 keeps it moving along as the timeline plays (as in SD downconvert from an HDV timeline).
    Ed
    [JeremyG] “No, the ioLD is an SD only device and does not handle HDV material.
    Perhaps it’s time to upgrade to HD?”
  • Jeremy Garchow
    December 3, 2007 at 4:07 am
    FCP6 supports real time dv downconverts from anything. I doubt it is full resolution and probably some sort of rt preview. If you are going to be working in HD, it’d be best to get an HD capable video card to work with. In my opinion anyway.
    Yours in sync,
    Bucko
  • Ed Dooley
    December 3, 2007 at 2:10 pm
    I agree, although it would be a nice bonus for owning an IO.
    Ed
    [JeremyG] “FCP6 supports real time dv downconverts from anything. I doubt it is full resolution and probably some sort of rt preview. If you are going to be working in HD, it’d be best to get an HD capable video card to work with. In my opinion anyway.
    Yours in sync,
    Bucko”
