Activity › Forums › Apple Final Cut Pro Legacy › HDV on a G4 – problems with crashing!
Jason Porthouse replied 20 years, 3 months ago 6 Members · 12 Replies
Jim Martin
June 8, 2006 at 10:29 pmGet a new TT as well at the same time, so when you need it you’ll have it. I’ve been bit in the arse twice after discovering I needed to upgrade both for use in Tiger, then having to wait on the upgrade CD’s
I guess I’m not forward thinking enough sometimesJim
Jason Porthouse
June 9, 2006 at 2:12 pmHi All,
Just an update on the crashing – now much better, after running Macjack, then resetting PRAM (I know, try the obvious first) and resetting the PMU. Seems to be stable at last… fingers crossed. I’ll let you know if the cure is permanent.
HDV on a G4 seems fairly usable in terms of UI ‘snappiness’ though (especially with the GSATA raid being so quick) though render times are high – still, it’s sunny outside and we all need regular breaks right??
Thanks for the advice all,
Jason
