Activity Forums Adobe Premiere Pro HDV–Monitor Window problem
  • HDV–Monitor Window problem
    Posted by John Greenstine on August 22, 2005 at 11:54 am
    When I open my 1080i HDV footage (in Premiere Pro 1.5.1 with HDV plugin) in a HDV 1080i project, the tape image in the monitor window is huge–too big to fit on both my dual head monitors combined. Plus, the monitor window size selector is grayed out. What gives? How can I see my entire raster in a normal size monitor window?
    John Greenstine replied 21 years, 1 month ago 3 Members · 3 Replies
  • Tim Kolb
    August 22, 2005 at 2:34 pm
    Try selecting a few workspace presets and see if it snaps into shape for you.
    or:
    The percentages are greyed out, but can you scale the window with the bottom right corner of the window?
    If you can…rearrange your workspace and save it and see if it holds.
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Steven L. gotz
    August 22, 2005 at 2:44 pm
    It is grayed out? At what size. Perhaps you could create a new DV project, set the size to “Fit”, close that project and open up your HDV project. It should be set to “Fit”.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • John Greenstine
    August 22, 2005 at 7:32 pm
    Thanks for the tips. Today, the scroll bars are gone from the monitor window and it scales larger or smaller smoothly with the entire raster visible, although the size function is still grayed out. Momentary hiccup in Premiere? Can’t say.
