Activity › Forums › JVC Cameras › HDV – mini-dv tapes
HDV – mini-dv tapes
Posted by Matt Sherman on March 28, 2007 at 2:34 pmI keep getting differing answers on this, but to record HDV can you use a normal mini-dv tape or do they have to be HDV specific?
Eva Ikari replied 19 years, 4 months ago 3 Members · 4 Replies -
Justin Ferar
March 28, 2007 at 8:05 pmThere is no difference which is the beauty of HDV cameras- no need for specialized tape. Whatever you do- just make sure to pick one brand/type and stick with it. Different brands have different lubricants which by switching will gunk your tape heads.
Eva Ikari
March 30, 2007 at 7:23 pmNot to change topic, but on the lubricant issue – it’s ok if you use different kinds of tapes from the same manufacturer right? I’ve been wondering about that, I have two different types of Panasonics…
Justin Ferar
March 31, 2007 at 12:51 amI can’t say yes with absolute certainty because there may be exceptions but in general you are correct. Brands stick with the same lubricants.
