Activity › Forums › Apple Final Cut Pro Legacy › HDV material in DV sequence
  • HDV material in DV sequence
    Posted by Daniel Ladeira on November 12, 2010 at 7:41 pm
    Hi, if I work with HDV 1280×720 material, in a dv sequence with pixel aspect ratio NTSC CCIR 601/DV – anamorphic 16:9, do i have a huge loss of quality? Even if i use Apple ProRess instead of dv/dvcpro for the compression?
    Thanx for the attention.
    Daniel
    Daniel Ladeira replied 15 years, 10 months ago 3 Members · 3 Replies
  • Michael Gissing
    November 12, 2010 at 9:38 pm
    Well you are downscaling in FCP to standard def so yes you will lose quality.
  • Paul Jay
    November 12, 2010 at 10:04 pm
    Don’t ever let FCP scale down your footage. Just don’t.
    Convert your HDV files in Compressor to SD ProRes.
    Make sure you use Frame Controls. Resize filter to BEST.
    This will work great in most cases.
  • Daniel Ladeira
    November 16, 2010 at 12:12 pm
    Well, thanx a lot for the attention. I’ll consider your considerations
