Activity Forums VEGAS Pro hdv material from final cut pro
  • hdv material from final cut pro
    Posted by Arthur Bueno on November 30, 2006 at 4:54 pm
    a cameraman provided me with some hdv material that he captured and pre-edited in fcp. They are some quicktime (mov) files that he put onto a dvd.
    Vegas cannot read them, Womble does show them, but if I convert them in Womble to mpg Vegas still cannot read them. Quicktime pro cannot read them either(!)
    Does anyone know how to exchange HDV material between Vegas and FCP?
    Arthur Bueno replied 19 years, 9 months ago 3 Members · 4 Replies
  • Gary Kleiner
    December 1, 2006 at 3:03 am
    Do you have the full version of Quicktime installed?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Arthur Bueno
    December 1, 2006 at 11:08 am
    I have quicktime player pro 7.1
  • Mike Kujbida
    December 1, 2006 at 2:24 pm
    Have you considered having the cameraman do a “print to tape” of what he’s edited so far and then dumping it back into Vegas?
  • Arthur Bueno
    December 1, 2006 at 3:51 pm
    thanks, I considered that and that is probably the path we’ll have to go.
    In this case it means that every time I want to exchange something I have to find/rent a hdv deck or camera. But that is not ideal either because I had to do color correction on a fcp hdv project, so preferred to have a similar timeline with trimmed clips from fcp (so I wouldn’t have problems colorcorrecting transitions).
    Here’s the misery:
    final cut needed a plugin to do AAF export, the AAF didn’t contain any media, I did trimmed media export with fcp’s mediamanager and it gave me in some cases the wrong clips (doesn’t read hdv-timecode well), and the clips that were the right portions didn’t open in Vegas (or VLC), or even in the PC version of Quicktime itself, only in Womble. They opened in Vegas only after I converted the stream in Womble to Program stream. Than they did play in Vegas, but very badly. It should be just an mpeg2 file?
    It seems to me outrageous that after all these years media and projects still can’t be exchanged properly between NLE’s and platforms.
    Found a thread with the same problem and no solution either, on the Sony forum: https://www.sonymediasoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=482066
