Activity › Forums › Apple Final Cut Pro Legacy › HDV, Log and Capture window won’t close, Force Quit…
  • HDV, Log and Capture window won’t close, Force Quit…
    Posted by First Last on May 27, 2009 at 10:32 pm
    When I’m done capturing HDV footage, the Log and Capture window will not close. It doesn’t do this when I capture NTSC footage.
    I’m using the easy setup’s.
    Any ideas?
    Production Associate
    Bend, Oregon, United States
    Chaci Goonbad replied 14 years, 9 months ago 4 Members · 3 Replies
  • Zane Barker
    May 28, 2009 at 1:36 am
    Try trashing the FCP preferences.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Steve Oakley
    May 28, 2009 at 4:40 am
    try command-W instead. I’ve found that when using a tablet, the close button on the window can be very tricky to get to work. OTH the keystroke always works.
  • Chaci Goonbad
    December 15, 2011 at 5:51 am
    hit the play button on the control screen for your device then go immediately to the x on the window and close it. Works for me.
