Activity Forums Apple Final Cut Pro Legacy HDV ‘live’ capture now
  • HDV ‘live’ capture now
    Posted by Andrew on September 30, 2008 at 7:49 am
    Hi
    I want to capture HDV footage ‘live’ via firewire using my Z1.
    I have all my AV settings set to HDV (as it will not allow me to have a none controllable device).
    I see the camera picture in the capture window but when I go to ‘capture now’ it captures every time for 6 frames and then says ‘capture was aborted due to timecode break.’
    I have unticked the following in my preferences:
    Abort EPT/PTV on dropped frames
    Abort capture on dropped frames
    And on timecode break I have it listed ‘warn after capture’
    I also have the unticked in the clip settings tab of the capture window ‘create new clip on Start/Stop.’
    What else should I be doing if this is even possible in HDV mode???
    Many many thanks
    Andrew
    Jerry Alto replied 17 years, 12 months ago 3 Members · 2 Replies
  • Jim
    September 30, 2008 at 2:07 pm
    It’s been a while since I’ve done this, but as I recall I had to start recording to tape first, then hit the Record Now.
    I should be able to check this later today and get back to you.
    Cheers,
  • Jerry Alto
    September 30, 2008 at 5:24 pm
    Andrew- You must have a dedicated firewire bus for HDV. No other firewire device can be active on the same bus. If you need an additional firewire bus buy an inexpensive PCI card.
    HTH,
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
