Activity Forums AJA Video Systems HDV, Kona LHe, & A/V Sync
  • HDV, Kona LHe, & A/V Sync
    Posted by Brian Conner on April 21, 2007 at 2:32 am
    Configuration:
    MacPro 3GHz w/ 4GB RAM
    Kona LHe & KL-Box
    Sony HVR-M25U
    Mackie 1402
    Mac OS v10.4.8
    FCP 5.1.3
    QT 7.1.4
    MacPro has 4 drives installed, two of which are striped RAID 0, and the RAID 0 volume is the Scratch Disk
    Problem: Clips captured from the Sony M25U as DVCPRO HD 29.97 lose A/V sync, about one second, and lose more sync as time progresses. Sync is right on while logging and while capturing. If the client places the playhead near the end of a clip and plays from there, the sync difference is the same as it is when she plays through that point from the beginning of the clip.
    Troubleshooting so far:
    1) Double-checked PCI Slot Utility – configured as 4 / 4 / 1 / 16, LHe
    is in Slot 3
    2) Created new user Account, logged in as new user. Same issue
    3) Checked A/V sync in FCP with external video/audio off. Same sync problem
    4) No 3rd party codecs installed
    5) Playback in QuickTime Player also has same A/V sync problem
    6) Double-checked that Playback Control is set to 0 frames Offset
    7) Repaired Permissions
    8) Ran First Aid on all volumes
    9) Client has blackburst generator, but it is not being used because the HVR-M25U does not have Ref In. Kona LHe is set to Free Run Reference (Aja Tech Support agrees this is an OK arrangement)
    10) Zapped PRAM
    11) Have not made animal sacrifice or swung a dead chicken over head
    while chanting
    Anything I’ve overlooked? Anyone experience this and found a solution?
    Brian Conner
    Brian Conner replied 19 years, 3 months ago 6 Members · 29 Replies
  • 29 Replies
  • Stuart Ferreyra
    April 22, 2007 at 2:51 pm
    Call AJA again. I believe there is a delay issue and must be set manually.
    I do my best not to work with HDV. Everytime we have, it’s been a hassle.
    Stuart Ferreyra
    Timecode Multimedia
    President
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
  • Brian Conner
    April 22, 2007 at 3:03 pm
    Playback Control Offset is set to 0 frames, but this thing seems to be happening during capture. It’s out of sync in QuickTime Player and in Aja’s VTR Exchange app.
    I’m beginning to suspect the Kona LHe card itself, but that seemingly doesn’t make sense. Even so . . . .
    I will be talking with Aja Tech Support first thing Monday morning, to find out what Hector had the client do to troubleshoot this when he spoke with them Friday afternoon.
    Related question: When capturing through a Kona LHe, should the audio be 24 bit? It’s 48k sample rate 24 bit. Is that correct?
    Brian Conner
  • Vince Gaffney
    April 23, 2007 at 1:35 pm
    I had the exact same problem with a m15u. I finally switched to capture audio over f/w instead of analog into the LHe and now it’s fine – perfect sync. I spoke to AJA several times but we never figured it out.
    vince
  • Walter Biscardi
    April 23, 2007 at 1:52 pm
    I have a Sony M15U connected to our Kona 3 via the HD10AVA box and we have zero audio sync issues capturing to DVCPro HD. Sounds like you have a frame rate differential or something going on there.
    I just checked a documentary we completed (over 500 shots captured) and it shows up as 24bit audio which is the default. All tapes shot 1080i/60 and captured at DVCPro HD 1080i/29.97 into FCP. No sync issues. We’ve completed three documentaries using the HDV to DVCPro HD workflow and it’s not a problem here. All audio and video captured using the Component / Analog Audio outputs of the deck through the converter to HD-SDI into our Kona 3.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Gary Adcock
    April 23, 2007 at 2:10 pm
    [Brian Conner] “Playback Control Offset is set to 0 frames, but this thing seems to be happening during capture. It’s out of sync in QuickTime Player and in Aja’s VTR Exchange app.”
    What camera was this shot with and are your extracting 24p from the HDV stream. Without camera info all of this is moot,
    IF the capture is off in both FCP and VtrEx then the tape is screwed up or some consumer HDV camera you are recording to has an offset built in.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Gary Adcock
    April 23, 2007 at 2:15 pm
    Additionally
    how are you getting the audio into the kona card Via XLR or are you capturing via the differently.
    more info brian.
    gary adcock
    Studio37
  • Brian Conner
    Thank you, Vince and Walter.
    The client called late last night to say she has captured several clips in a row without any sync issues. But she said she did them with Capture Now.
    While I was on site just before the NAB, I experienced the sync problem with the first two clips we captured, but then it corrected itself the evening before I left from there for the NAB. I assumed it was resolved.
    I’m not making that assumption, and told her to call me today to tell me if the sync issue returns after an overnight shutdown,or not.
    I’ll also be calling Hector at Aja later this morning to get a recap of all the things he had her do last week.
    BTW, Vince, I’ve never heard of taking the audio through FW while the video is going through the Kona card. I would have never figured audio and video would be in sync doing that. Heck, I didn’t even think it was possible to do that.
    Brian Conner
  • Brian Conner
    April 23, 2007 at 2:19 pm
    Thank you, Gary.
    They are using a Sony Z1U. Please see my precious reply to Walter and Vince for more info.
    Also, they are using a Sony UWP-C1 wireless mic. Playback from the M25U shows perfect sync. The sync problem only shows up after capture.
    Brian Conner
  • Brian Conner
    April 23, 2007 at 2:21 pm
    Forgot to answer the other question you asked, Gary. This is 29.97 all the way. No 24p at all.
  • Brian Conner
    April 23, 2007 at 2:32 pm
    Audio signal path:
    M25U analog audio outputs > Mackie 1402 > KL-Box > Kona LHe
    Video signal path:
    M25U HD analog component output > KL-Box component input > Kona LHe
    However, we are having problems using the KL-Box. Aja has sent a second one that has the same problem. The HD-SDI Out does not send a signal to the Blackmagic HDLink box. When we switch to the LHe’s octopus cable, it works fine. Aja Tech Support is puzzled. At the moment, the octopus cable is connected in place of the KL-Box.
    But WRT the sync issue, it makes no difference whether we use the KL-Box or the octopus cable.
    BTW, even though previously I had a specific conversation with the client about 29.97 vs 24p WRT to the Z1U, I just now sent an Email to her asking for confirmation that the Z1U really is set for 29.97.
Page 1 of 3
