Activity Forums Apple Final Cut Pro Legacy HDV into standard DV FCP project
  • HDV into standard DV FCP project
    Posted by Tim Hore on July 24, 2008 at 12:43 pm
    I have a project with both HDV and DV Cam material. Project and sequences set to DV Pal (i am in the UK) and I want to import my HDV material into this project. So far I have captured the material into a separate new HDV project. Camera (Canon XLH1 has a down convert selection) but I think there must be a better way. Any ideas?
    Thanks in advance
    Tim
    Tympani Productions
    Rafael Amador replied 18 years, 1 month ago 3 Members · 2 Replies
  • Stuart Simpson
    July 24, 2008 at 12:59 pm
    [Tim Hore] “Camera (Canon XLH1 has a down convert selection)”
    Yeah – this is the best option if you want to work at DV – just set the camera to downconvert and capture at DV over firewire.
    -Simmie
    3 MacPros – Kona 3 & Kona LH
    2 G5s – Kona LH
    2 G4s – Cinewave
    xbox360, Wii, PSP, PS2
    https://www.speak.co.uk
  • Rafael Amador
    July 24, 2008 at 1:32 pm
    I don’t know how good is the downconversion from the camera. But having all the stuff already captured in HDV, I just would treat it as DV footage. At least with FC6 will work without problems mixed in the same time-line.
    You just need to drag and drop the footage bins from the HDV project Browser to the DVCam one.
    Rafael
    http://www.nagavideo.com
