Activity › Forums › Apple Final Cut Pro Legacy › HDV import issues?
  • HDV import issues?
    Posted by Thunkgrass on March 1, 2006 at 12:45 am
    Greetings. We just got our new HVR. Using the camera for capture, i set my FCP easy set up to HDV 1080-60. 2 things happened when i captured…1. i used “capture now” and captured about 18 minutes of footage. when the capture ended it automatically divided up my footage into 34 different clips. the only thing i can figure out is it read when i started and stopped recording?
    2. when i put a clip into the timeline it shows that the clip needs to be rendered? i thought it was real time just like DV?
    -Travis
    Shane Ross replied 20 years, 7 months ago 2 Members · 3 Replies
  • Shane Ross
    March 1, 2006 at 1:35 am
    1) Yes…it breaks it up where the camera was started and stopped.
    2) After you change the easy setup, make a new sequence. Don’t use the one already in the project. Make a new sequence and start cutting into that one. Should work fine.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Thunkgrass
    March 1, 2006 at 3:20 am
    thanks shane,
    one question…when i opened a new project i set the easy setup to hdv 1080-60 then captured. are you saying i have to reset the easy set up after i capture? or do i need to change the sequence settings in the audio/video settings to something else?
    thanks
    travis
  • Shane Ross
    March 1, 2006 at 6:18 am
    No. After you choose your easy setup, THEN you capture your footage. Then need to create a new sequence. THAT new sequence will have the settings that match your easy setup and captured clips. DO not capture before you have chosen an easy setup.
    Shane
    Alokut Productions
    http://www.lfhd.net
