Activity Forums Adobe Photoshop HDV illustrations are squished after import into FCP
  • HDV illustrations are squished after import into FCP
    Posted by Cardinalman on December 4, 2005 at 6:25 am
    I read that there was no need to change the pixil ratio when importing into final cut when you choose the HDV preset with square pixels. Why is mine squished top to bottom. Anyway, more important is how can I change the pixel ratio to import the illustrations into FCP so that they look normal?
    Mike
    Ben Insler replied 20 years, 9 months ago 2 Members · 1 Reply
  • Ben Insler
    December 7, 2005 at 10:26 pm
    There’s no need to change the pixel ration if you’re importing your image into an HD sequence in FCP (because HD works with square pixels). Make sure your FCP sequence and pixel aspect ratios are set to HD and not DV (click on your sequence and press command+0).
    -Ben
