Activity Forums Apple Final Cut Pro Legacy HDV idiosyncrasies
  • HDV idiosyncrasies
    Posted by Bob Flood on April 4, 2006 at 8:06 pm
    Hey All
    am wrapping up a job and as its really my firsdt of its kind i wanted to get some feedback as to flow
    For reasons i wont bore you with I had to do an hdv job starting by digitizing all the footage into fcp4 at dv downconverting via an M10U,
    editing at dv, then recapturing selects at HDV off the same deck.
    man what a thrash!
    1. when i go to recapture the HDV footage, everytime i cross a time code break FCP generates a new clip AND DOES NOT ALWAYS LINK IT TO THE RIGHT CLIP IN THE SEQUENCE. so ikeep getting these recconnect errors (i will start with one clip to recap, and after i have 4!)
    2. Basic titles and filters take foreeeeeevvvvvvveeeeeer to render, and i am ona dual 2.7
    3. In regards to 1, i was able to succesfully recap about 50 shots, and only had to manually relink 6.
    4. I have to reposition all the titles and graphics from my DV offline cuz now the frame is bigger!
    5. I have a kona card lh and i wonder if i can do either of the following: Capture into the catd DVCPROHD component from my M10U controlling via firewire OR capture into the card DVCPROHD component using a Tao L-Port to go between the rs 422 and the M10U
    LANC?
    thanx for any and all help!
    bee eph
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 20 years, 5 months ago 2 Members · 2 Replies
  • Acoustic_overdrive
    April 5, 2006 at 1:01 am
    [Bob Flood] “1. when i go to recapture the HDV footage, everytime i cross a time code break FCP generates a new clip AND DOES NOT ALWAYS LINK IT TO THE RIGHT CLIP IN THE SEQUENCE. so ikeep getting these recconnect errors (i will start with one clip to recap, and after i have 4!)”
    I can make one small suggestion, which is to set your User Preferences to “On timecode Break: Warn after Capture” rather than “make new clip”, this solved the same problem for me.
  • Bob Flood
    April 5, 2006 at 12:36 pm
    thanx
    i have actually done that, and to no avail.
    in general i am always leary of logging across tc breaks, but i did not log this one
    bee eph
    Bob Flood
