Activity Forums Apple Final Cut Pro Legacy HDV graphics
  • Posted by Brian Pitt on June 27, 2007 at 7:37 pm
    I am shooting most of my stuff HDV these days, but I’m still delivering primarily SD. It seems like most who have a similiar workflow are capturing native HDV, editing on an HDV timeline, and then down converting to SD via compressor when the edit is complete. This seems to work just fine for me, but I have a question…
    I am working on a project that is very graphic intensive (full screen graphics). In this case would it be best to still work on an HDV timeline and make the graphics with a much larger resolution, (much larger files) or should I just downconvert during capture, edit on a DV timeline, and use the standard 720×480 graphics?
    Has anyone tried both ways and had better results with one of them?
    Chris Borjis replied 19 years, 2 months ago 5 Members · 6 Replies
  • Jerry Alto
    June 28, 2007 at 3:49 am
    Brian- If you are running FCP6 there is an interesting option in your HDV project sequence settings. Select the render control tab and under render>codec> choose Apple ProRes 422. This new option may be just what you are looking for.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
  • Chris Borjis
    June 28, 2007 at 4:14 am
    I leave the codec renderer at HDV until I’m done, then I change it to ProRes (deleting hdv renders first) then render that out.
    Very clean!
  • Brian Pitt
    June 28, 2007 at 2:18 pm
    I don’t have FCP 6 just yet. What would you suggest in the meantime?
  • Randall M
    June 28, 2007 at 4:45 pm
    Borjis,
    regarding deleting the original render files, are you just going to the render folder and trashing everything?
    Randall
  • Chris Poisson
    June 28, 2007 at 6:52 pm
    Brian,
    I’m using native HDV in SD timelines with NTSC sized graphics, for SD stuff this works great, render in ProRes or 8bit uncompressed.
  • Chris Borjis
    June 29, 2007 at 4:18 am
    [Randall M] “regarding deleting the original render files, are you just going to the render folder and trashing everything?”
    yes
