Activity › Forums › Adobe Premiere Pro › HDV footage needs rendering when captured in Adobe Premiere CS3?!!!
Liam Sanderson replied 15 years, 7 months ago 7 Members · 15 Replies
Liam Sanderson
February 13, 2011 at 9:54 amHi thanks for the feedback.
Hard drives have been defragged and have tons of space.
All Premiere projects are completely uniform. The video is shot using a Canon HV40, on the main HDV 1080i setting.
I then use the HDV 1080i50 preset when captruing on Premiere.(I’m UK based btw). Have tried capturing with HDV-Split and still have the same problem.
As said before, this creates no problems on the rest of the computers, i just have the rendering problem on a select few.
Chris Buttacoli
February 13, 2011 at 5:36 pmHow difficult would it be for you to swap one of the working machines HD with one of the non-working machines? Just to test if it is the harddrive.
Ed Hickey
February 13, 2011 at 6:51 pmI’m curious what would happen if a video file captured from one of the “working” computers was copied and pasted to one of the troubled units.
If that footage also becomes affected after importing, it might point to a drive or timeline issue. If it stays clean with no rendering required, it might point more directly to something in the capture process. -
Alex Gerulaitis
February 14, 2011 at 7:55 pmThat’s a great suggestion (swap hard disks between a “problem” and a “no problem” systems) – I’d try that first; if the issue persists in a different system, then I’d try copying a project from a “problem” system to a “no problem” one.
Also, a quick disk benchmark test to run in administrative command prompt: “winsat disk -drive C:”. Takes a minute or two to complete; look for “sequential” numbers after it’s done.
Alex
DV411 -
Liam Sanderson
February 15, 2011 at 7:46 pmThanks for all the help.
I finally figured it out. I had installed the Main Concept Mpeg Pro HD plugin on a couple of the computers.
I had totally forgot about it, I uninstalled the plugin and the problem was solved.
