Activity Forums Apple Motion HDV footage is being squeezed. Help!
  • HDV footage is being squeezed. Help!
    Posted by Brian Pitt on January 14, 2008 at 7:02 pm
    Everytime I import any HD footag into Motion, it gives it a horizontal squeeze so that it becomes 4:3. Is there a simple something I need to do to fix this? My project is set at HDV1080i. that is the same as the footage I’m importing.
    Brian
    Brian Pitt replied 18 years, 8 months ago 3 Members · 3 Replies
  • Tim Schultz
    January 15, 2008 at 10:20 am
    If you need to see your Footage in the correct aspect ratio
    go to the View Options in the Right Hand Corner and toggle the “Correct for Aspect Ratio” menu item
    This should adjust the aspect Ratio for the Footage
  • Robert Grove
    January 15, 2008 at 12:09 pm
    Hi there,
    Have you checked if “Correct for Aspect Ratio” is on ?
    It must be on!
    Hope that helps 🙂
  • Brian Pitt
    January 16, 2008 at 4:51 pm
    Thanks! I’ll give this a try. I’ve never worked with 16:9 footage in motion…
    Brian
