Activity › Forums › Apple Final Cut Pro Legacy › HDV Footage into HD & SD Timelimes
  • HDV Footage into HD & SD Timelimes
    Posted by Justin Ward on April 6, 2008 at 8:23 pm
    I have to digitize several HDV tapes off a Sony FX-1 in to FCP 6.0.2. I am wondering what is the best codec and specs to use based on the following montages/timelines that I need to create from this footage:
    TIMELINE 1 needs to be an HD quicktime for broadcast on an HD channel. (They want a QT that is 720p 30. 59.94 48 khz).
    TIMELINE 2, same montage, needs to be down-converted to SD Quicktime for broadcast (8 bit uncompressed .mov). CAN I PROTECT THE SHOTS SHOT FOR 16×9, OR DO I NEED TO CROP? OR WILL LETTERBOX DO IT FOR ME?
    Another longer timeline of the same footage, TIMELINE 3, needs to be added into an existing SD 16×9 Timeline, and made into a DVD (thru DVD Studio Pro) for display on an HD monitor.
    TIMELINE 4 needs to be a Beta copy of the Raw Footage as a B-roll tape.
    Help…
    Justin Ward replied 18 years, 6 months ago 2 Members · 2 Replies
  • Russell Lasson
    April 6, 2008 at 9:58 pm
    I would suggest digitizing to either ProRes or DVCPROHD, then editing every sequence at HD. From there you should either downconvert in software or use a Kona 3 for output to beta.
    Your question about how to deal with 16×9 in SD is really up to you and your client. You can either go anamorphic, cropped, or letterboxed. It’s up to you.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Justin Ward
    April 8, 2008 at 12:46 am
    Can’t digitize with either… With the Camera as the deck, the only option I can actually capture is CAPTURE PRESET: HDV and DEVICE CONTROL PRESET: Sony HDV Firewire, which makes 1440 x 1080 29.97 fps HDV 1080i60.
    What should the sequence preset be?
    So can I use that and export a quicktime as 720p 30 from that?
