Activity › Forums › Apple Final Cut Pro Legacy › HDV Firewire output mystery
  • HDV Firewire output mystery
    Posted by Caspar Stracke on September 12, 2009 at 11:55 pm
    Hi folks,
    sorry probably a famous problem that one of you can refer me to some similar cases but couldn’t find:
    I am new in the HDV realm ….desperately try to connect a SONY HDV deck (HVR M15 U) to a an iMac (2.93 Intel Core Duo, 4 Gig Memory running 10.5.8)
    Tried for hours to find out why FCP (6.0.6) doesn’t recognize the deck in all possible HDV protocols.
    – capturting works fine
    – DV mode everything works fine
    But when I try to print to tape I cannot even find the deck in video playback.
    Any help greatly appreciated!!!!
    Caspar Stracke
    Caspar Stracke replied 17 years ago 2 Members · 2 Replies
  • Zane Barker
    September 13, 2009 at 3:12 am
    First off HDV is NOT DV. It is a completely different format with different properties.
    HDV is GOP and iFrame based codec (if you are going to be working in HDV you really should study up and learn about GOP and iFrame) Because of this structure, HDV does not play out FireWire like DV does.
    Here are a few links that might help.
    https://library.creativecow.net/articles/kolb_tim/demystifying_hdv.php
    https://forums.creativecow.net/thread/8/1041729
    https://www.kenstone.net/fcp_homepage/hdvxdv_wright.html
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Caspar Stracke
    September 13, 2009 at 5:31 pm
    Dear Zane,
    Thansk so much. Yes some homework to so, for sure.
    I have avoided all the drawbacks for HDV editing (simple denial 😉
    especially all the i-frame and Grand Old Party aspects.
    So far editing went really OK in HDV, its just the connection to the deck for print to video. It worked..and now stopped working..:-(
