Activity Forums Apple Final Cut Pro Legacy HDV Field Dominance?
  • HDV Field Dominance?
    Posted by Wolfgang on May 29, 2007 at 2:44 pm
    I have been capturing some HDV footage from a Canon HV20. It was shot in the 24p mode but I am just going to use it as is with the pull down.
    I have captured with the “easy set up” HDV codec 1080i60 and am editing in a 1080i60 timeline.
    With everything in preset, you can see the interlacing. It really looks bad! When I go into the sequence settings (HDV easy set up) the field dominance is set to “none”.
    If I change this to “upper” or “lower” it fixes the interlacing problem and looks good.
    The problem now is that every shot comes into the timeline “green” un-rendered.
    What’s up? Is there any way to do this without all the rendering or bad interlacing?
    Thank you for any help
    David Roth weiss replied 19 years, 4 months ago 2 Members · 1 Reply
  • David Roth weiss
    May 29, 2007 at 4:54 pm
    For the record, all interlaced HD video is upper field first. If you’re monitoring on a computer monitor you will see the interlacing. And, if you shoot progressive, but edit interlaced, that changes the frame rate and you will have to render.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
