Activity › Forums › Adobe After Effects › HDV – FCP to AE back to FCP
Posted by Jay Verheyen on November 11, 2008 at 6:47 amI am editing a HDV video in FCP. I moved files to AE for effects work using the Apple intermediate codec. My questions is about moving the footage back to FCP for final editing and output. What is the best format to export HDV footage from AE to FCP for highest quality and fasted render time?
Jan Sherlink replied 17 years, 10 months ago 3 Members · 5 Replies -
Jan Sherlink
November 11, 2008 at 3:22 pmhighest quality and fastest rendertime;
quicktime uncompressed or animation @100% or “none”these would be the best codecs !
cya,
Jan
Jonathan Wiley
November 11, 2008 at 4:31 pmcomposting and effects pros use image sequences and not wrapped video files for countless good reasons. personally I prefer to convert my video to 16 bpc tiffs.
Jay Verheyen
November 11, 2008 at 8:05 pmThanks for the input! Would you mind pointing out a few of those countless reasons of why tiff sequences are preferred over wrapped files?
Jonathan Wiley
November 11, 2008 at 11:03 pmwell… they’re universally excepted, no codec hassles, you can crash a render and pick up on the frame where you went down at without re-rendering the previous frames, you can make changes to a range of frames without rendering others outside of that range, you can batch process in apz like photoshop, keyframes every frame, etc.
Jan Sherlink
November 11, 2008 at 11:21 pm“Countless reasons” tends to be synonym for “because we’re used to it”
Not to offend anyone, but there are “countles reasons” to use a container too. They both have their pro’s and con’s.
When to use them, might be a better questionsome reasons;
Multiprocessing benefits from Image sequences, each core can easily access an Image frame for reading and they can write their own rendered Image. With containers, only one core can write to the file so that core needs to gather all the images (slower).
Moving around a few 100.000’s images over network and Harddrives, gets really slow, AVI or QT copies at a higher speed
If there’s something wrong in an Image Sequence, only render the wrong Images, in a Container you’ll need to rerender the complete clip.
If your going from AE to FCP and you have something like BlackMagic or AJA, render in their uncompressed codec, no sequences needed here.
If you have an AVI or QT, just doubleclick and it’ll play, even with audio 😉
Image sequences don’t need codecs so everybody can open them…
ok that was an old one 😉 everybody can open Quicktime”none” and AVI”uncompressed”, it’s installed in every OS.Blackmagic’s framelink looks like the best of both worlds !
So,
use what you want, every job needs it’s own approach, just stay away from those interframe compressions.cya,
Jan
