Activity Forums Apple Final Cut Pro Legacy HDV FCP capture is really 188 x 1062???
  • HDV FCP capture is really 188 x 1062???
    Posted by Steven Brown on March 16, 2008 at 8:48 pm
    Apple HDV – Shot with Sony Z1
    1888 x 1062 Pixels VS 1920 x 1080 Pixels
    I took a 5 second clip and…
    1. When I capture HDV and open it in QT the QT Inspector says:
    Format: Apple HDV 1080i60, size 1440×1080 (1888×1062)
    Normal Size 1888 x1062 Pixels
    2. Export from Final Cut Pro Sequence using File, Export, QuickTime Movie, then open it in QT, the QT Inspector says:
    Normal Size 1920 x1080 Pixels
    3. Export again from Final Cut Pro Sequence using File, Export, Using QuickTime Conversion, Option, Compression Type: HDV 1080i60, then open it in QT, the QT Inspector says:
    I understand that the Sony Z1 chip is 1440×1080 pixels are the pixels are not square, using a 1.3 ratio, but if you do the math 1440 times 1.3 equals 1872. So maybe it is a little off and and not quite 1.3 and comes out to 1888. I can handle this.
    SO MY QUESTION IS: Exporting from Final Cut Pro, QT export VS. using Conversion HDV1080i60 export. Let’s all watch the pixels grow.
    A. Why is the HDV capture at 1888×1062 pixels?
    B. When you export using a QT export, if it increases pixels does this degrade your image by stretching it?
    C. I’ve been shooting in HDV for a few corporate clients with the intension of someday making a Blu-ray disk that they can use at trade shows. However for now they are happy with 16×9 SD DVDs. If Apple ever gets the head out of their but and make Blu-ray possible, what should my files be? As in type of exports to keep on my HDs until…
    My answers to myself.
    A. No idea on this, but from what I have read it’s better to capture using a better format than HDV.
    B. By increasing the pixels it must degrade the image.
    C. Blu-ray is 1920 x 1080 so the image is going to be stretched sometime in the process, either on export or latter when using Compressor to make the Blu-ray file.
    Steven Brown replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
