Activity Forums Apple Final Cut Pro Legacy HDV export aspect ratio problem compressor
  • HDV export aspect ratio problem compressor
    Posted by Carl Rohumaa on September 7, 2008 at 2:18 pm
    This is driving me mad! I really hope someone can show me where I am going wrong!
    Trying to export my sequence as HDV but no matter what I do it never ends up with the right aspect ratio!
    My source files are reported by QT to be:
    Apple HDV 1080i50 1440 x1080 (1888 x1062) Millions 25FPS 27.63mbits/s
    Normal Size 1920×1080
    my sequence in FCP is set up for 1080i50
    no matter what settings I use in compressor on export it always comes out stretched. It looks fine in FCP.
    the files I am ending up with are reported by QT to be the same as the source except that under Normal size it says 1888×1062?????
    I am pretty confused as to what is happening. I spent all last night until 5am trying all the settings Combinations and at no point did I end up with the right ratio! Square pixels or not. Help much appreciated as I have to show this film at a show on Wednesday! I want to re import the flattened HDV into FCP so I can print to video. Or just play back the HDV
    Carl Rohumaa replied 18 years ago 2 Members · 2 Replies
  • Carl Rohumaa
    September 7, 2008 at 3:45 pm
    OK this is really strange. On my old laptop I had a go at replicating the settings under FCP version 6.0.0 and it works. Problem is my project is on my new laptop with version 6.0.4 and I can’t open it on my old set up.
    So to re-cap. The same files and settings give me the correct aspect ratio in version 6.0.0 but come out stretched in version 6.0.4
    Pretty stressed now 😉
    Anybody else been here?
  • Carl Rohumaa
    September 7, 2008 at 4:32 pm
    Ahhhhhh so I have found out what has happened. I checked the motion tab settings and some how all of the clips aspect ratios under the distort parameters are on -2. Setting this to 0 corrects the problem for export.
    The edit is quite complex. Anybody tell me how to “batch” change all the clips motion tab distort aspect ratios?
    Not sure how I ended up here but hey at least there seems a way out!
