Activity › Forums › Apple Final Cut Pro Legacy › HDV editing in Final Cut Studio 2
Posted by Bob Archer on May 15, 2007 at 5:42 pmHas anyone cut in the HDV format in Final Cut Studio 6? Is it truly native editing, or is there still large conform times when adding effects, titles, correction, etc to the clips in the timeline?
Management is willing to upgrade the editing machines based on an HDV job we have coming in and I would like to know if any of you have experienced any large differences with HDV workflow between FCP 5 and Final Cut Studio 2. Is there less render time, is there less conforming on output, andy other issues?
Thanks in advance for your input.
Sirmausalot replied 19 years, 3 months ago 9 Members · 20 Replies -
Jerry Hofmann
May 15, 2007 at 5:47 pmFCP 6 hasn’t shipped. Those who have worked with it cannot talk…
FCP 5 works with HDV “natively” now… conforming times has nothing to do with the application… it has to do with the nature of native HDV… it HAS to be conformed. it’s GOP structure demands that. It’s not all i frames like DV is. it’s an mpeg stream where only a few frames contain all of the information about them. If you don’t edit on one of these “i” frames, the stream must be “conformed” to be the same GOP (group of pictures) structure that the original stream contained. Like Sony’s format only has 1 in 15 frames that is an i frame… so if you don’t edit on one of them… it has to reconform if you work in HDV natively.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Tom Wolsky
May 15, 2007 at 5:50 pmYou do realize that FCP6 has not yet been released, don’t you? No beta tester could comment on this. Nothing anyone said at NAB that I know of indicates any changes in FCP in this regard. It’s still native HDV with conform for output. There will be ProRes ingest however, which might be a solution for you.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Walter Biscardi
May 15, 2007 at 5:53 pm[bob archer] “Has anyone cut in the HDV format in Final Cut Studio 6? Is it truly native editing, or is there still large conform times when adding effects, titles, correction, etc to the clips in the timeline?”
It’s not shipping yet, nobody has used it except Beta Testers and of course they cannot speak publicly about that.
HDV by its very nature requires the conform process because it’s an MPEG-2 Long GOP format. Has nothing to do with FCP or your system.
If you don’t want the long conform process, capture / edit in another format. We convert HDV to DVCPro HD during capture right now. We will test out the new Apple Pro Res 422 codec as an alternative when we receive FCP 6.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Bob Archer
May 15, 2007 at 6:07 pmSo, it’s the nature of the codec which requires it to conform. I understand that, hence it’s ability to bring HD to a lower data rate / file size.
I am aware the program hasn’t reached release, but I remember there being two workstations set up at NAB that were supposed to be showcasing the new functionality with HDV. I was just looking for a bit of insight on what improvements or changes FCP will have in making workflow faster for this format.
I do like the idea of doing an offline with the ProRes, does anyone know what the transcoding times are supposed to be when using ProRes?
Tom Wolsky
May 15, 2007 at 6:15 pmProRes would hardly be an offline solution for HDV. It would be your finishing solution.
All the best,
Tom
Walter Biscardi
May 15, 2007 at 6:25 pm[Tom Wolsky] ”
ProRes would hardly be an offline solution for HDV. It would be your finishing solution.”exactly. there would be no reason to go back to HDV, that’s why Apple introduced Pro Res.
Bob Archer
May 15, 2007 at 6:25 pmSo, the answer would be to transcode all the HDV footage to ProRes 422 and edit and output with it that way, then the conforming after every edit or effect would be relieved, correct?
Michael Sandness
May 15, 2007 at 6:32 pmThe first rule about fight club…
Michael Sandness
Colorist-Finishing
Splice Here, Minneapolis MN
http://www.splicehere.tv -
Winston A. cely
May 15, 2007 at 6:35 pmI must have misunderstood in my reading, but your saying that you could actually finish and broadcast Pro Res? So – other than intensive color correction and grading – there’s hardly any reason to edit in a native HD format, if Pro Rez can give you quality that matches the original HD picture?
Winston A. Cely
Editor/Owner | Della St. Media, LLC“If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
Mac Pro 3GHz Dual-Core Intel Xeon
4 GB RAM | Final Cut Studio 5.1.4 | Aja Kona LHe
