Activity Forums Apple Final Cut Pro Legacy HDV, DVCPRO, DVCAM????
  • HDV, DVCPRO, DVCAM????
    Posted by Joe Mar on July 31, 2008 at 3:37 pm
    I am a video producer who is about to step it up to HD for the first time and I was looking for some advice as to which format would b e best for professional picture quality and (more importantly) easy video capturing and editing.
    I just want to make sure i don’t go with a format that’ll make me sorry in the editing room. At the end of the day, the camera selection will be up to my DP, but I figure having some info ahead of time can’t hurt.
    Just to be specific as possible, the project is a semi-cinematic music video (so I don’t need feature quality picture, just something that looks better than basic 3CCD) and I will be editing on a FCP system (any advice about harddrives for HD storage would be appreciated as well.)
    Sorry for rambling but I’m at a loss. Thank you!
    Joe Mar replied 18 years ago 4 Members · 5 Replies
  • Chris Borjis
    July 31, 2008 at 4:30 pm
    sounds like DVCPRO-HD 1080 is what you might want.
    Simple, does not require a massive disk array and it just works.
  • Joe Mar
    July 31, 2008 at 5:09 pm
    So, you think something like the Panasonic HDX-900 DVCPro HD would get me the picture and post pro flexibility I’m looking for?
  • John Foley
    July 31, 2008 at 6:42 pm
    HDV is Sony’s answer to High Def using 4:2:0 color space. What does that mean to you? A good HDV camera takes a good looking 16:9 video but is a real paid to edit because of the limited color space.
    DVCPro HD is High Def at 4:2:2 color space and also produces a great looking video but is easy to edit with camera’s like the HVX-200 and HPX-200 being P2 media instead of tape and color space very easy to capture and edit.
    DVCAM is SD only – basically 4:1:1 color space as is any DV 4:3 footage. Definitely not High Def. Some use it as anamorphically but that just reduces the actually pixel count of a frame below that of a 4:3 frame.
    XDCam is Sony’s High Def camera but still uses 4:2:0 color space (like HDV) and media cards, not tapes.
  • Walter Biscardi
    July 31, 2008 at 7:22 pm
    [Joe Mar] “So, you think something like the Panasonic HDX-900 DVCPro HD would get me the picture and post pro flexibility I’m looking for?”
    That’s a solid HD camera and we’ve used it quite a bit on projects here. Might be overkill depending on your budget. HVX-200 is also a solid camera, but of course you have to use the P2 workflow for that. That’s very cool and getting a lot easier to work with as the format matures.
    A Sony HDV camera is a fantastic camera in the hands of a good DP. We’ve used it on documentaries here, but we convert the footage to DVCPro HD during ingest and edit in that format. I just experimented with rendering the footage to ProRes HQ in Color and than finishing in that format and it did look absolutely fantastic.
    DVCPro HD is a proven HD format and has been used for years on broadcast programming, documentaries and independent films. Easy on the hard drives too as it’s a small format.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Joe Mar
    July 31, 2008 at 8:50 pm
    Thank you both for the information. It was very useful. I think I’ll end up using one HDX-900 or two HVX-200’s, depending on whether or not my DP can take full advantage of the higher end model. Thank you again!
