Activity Forums Apple Final Cut Pro Legacy HDV Documentary using some VHS Footage
  • HDV Documentary using some VHS Footage
    Posted by Carlos Berrios on April 26, 2006 at 11:02 am
    I’m about to start work on a documentary about music that goes back to the early eighties. I’m planing on shooting interviews 720P with the JVC HDV camera (GY-HD100U). The flashback performances are all on VHS tapes that I’ve collected from various artists. My question is will it make a difference whether I capture the VHS footage as Mini DV, Standard Def, or 720P HDV, being that the original VHS tapes are what they are?
    David Roth weiss replied 20 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Daniel5000
    April 26, 2006 at 1:50 pm
    Not much experience here but:
    Personally I would consider converting all the VHS to an SD format and not to 720P as I would think the enlargement would make the already VHS look even worse.
    And depending on your workflow you might be down converting all you
  • Carlos Berrios
    April 26, 2006 at 2:26 pm
    Thanks for the input Daniel. I know that a year ago I wouldn’t have cared but with the new HD-DVD players coming out this year I would like to keep this project HDV and/or up-rez to HD. It’s just that I hate how standard def looks on HD televisions and I’m finding them more and more in peoples homes. Maybe I’m wrong about this and someone could school me.
  • David Roth weiss
    April 26, 2006 at 3:50 pm
    Carlos,
    When doing historical documentaries, typically I want our vintage stock footage to be degraded and chewed-up because it makes audiences feel like they’re being taken back in time in a time machine. VHS blown up to 16×9 has that same effect, especially if you colorize it properly or give it a filmlook. Also, you might want to consider shooting it off your monitor with your HDV camera, that gives it a great look too.
    DRW
  • Drizzt_g
    April 26, 2006 at 5:47 pm
    I agree with David that shooting you VHS on a monitor is a good idea and its probably the easiest way of dealing with the workflow problem. I have never seen VHS uprez to HD, but it can’t be pretty.
  • Carlos Berrios
    April 26, 2006 at 5:54 pm
    Thanks Guys. You’ve given much to think about. I really appreciate your time and advice.
  • Mike Schrengohst
    April 26, 2006 at 9:56 pm
  • David Roth weiss
    April 27, 2006 at 4:53 pm
    Mike,
    When posting a link, if you highlight it and hit the blue L button on the right above you will make it an active link, making life a whole lot easier for all of us other Cows.
    For example:
    https://www.redgiantsoftware.com/instanthd.html
  • David Roth weiss
    April 27, 2006 at 4:55 pm
    Oops, it not working now for soem reason…
